pnophotography
Aug 25, 2019Star
Readynas 312 Ram upgrade
Hi Can someone let me know if I can do this with this server Readynas 312. I would like to install 8GB PC10600 DDR 3 1333MHz 204 Ram not 4GB will it work ?
Marc_V
Aug 25, 2019NETGEAR Employee Retired
Not really sure if 8GB is supported or will have success but there was success on using 4GB module. You can check it here.
HTH
Regards
- StephenBAug 26, 2019Guru - Experienced User
pnophotography : Someone else tried this and got 4 GB to work - but 8 GB failed failed for them. https://ptarmiganlabs.wordpress.com/2014/02/09/readynas-rn312-8gb-ram-fail/
- SandsharkAug 26, 2019Sensei
The 312's Atom D2700 processor only supports 4GB (even if Netgear had installed two SODIMM slots). Hey, at least it is upgradeable -- trend on newer NAS is it's soldered in.
- pnophotographyOct 13, 2019Star
Thank you all for getting back to me.
