pnophotography
Aug 25, 2019Star
Readynas 312 Ram upgrade
Hi Can someone let me know if I can do this with this server Readynas 312. I would like to install 8GB PC10600 DDR 3 1333MHz 204 Ram not 4GB will it work ?
Aug 26, 2019Guru - Experienced User
Marc_V wrote:
Not really sure if 8GB is supported or will have success but there was success on using 4GB module.
pnophotography : Someone else tried this and got 4 GB to work - but 8 GB failed failed for them. https://ptarmiganlabs.wordpress.com/2014/02/09/readynas-rn312-8gb-ram-fail/
Sandshark
Aug 26, 2019Sensei
The 312's Atom D2700 processor only supports 4GB (even if Netgear had installed two SODIMM slots). Hey, at least it is upgradeable -- trend on newer NAS is it's soldered in.
- pnophotographyOct 13, 2019Star
Thank you all for getting back to me.
I did get 4GB Ram to work
