RPB123
Mar 29, 2020Aspirant
ReadyNas 312 VPN Access
Hi there, I have inherited the administration of a ReadyNas 312 unit. Currently there are 2 senior users who are able to access the unit remotely via VPN - they are in their own user group. ...
- Mar 29, 2020
RPB123 wrote:
Sorry am I being dumb - is VPN access done via my router and not the ReadyNas?
There's more than one way to set this up, so you will need to figure out what your predecessor did.
ReadyCloud is enabled on the cloud page of the NAS, and managed from http://readycloud.netgear.com
Though of course you can use a VPN hosted by your router - which is what I do myself.
It is also possible to deploy ZeroTier (which is done with an app on the NAS). That would be managed at https://my.zerotier.com
RPB123
Mar 29, 2020Guru - Experienced User
