bertmaster
Jan 11, 2018Aspirant
ReadyNas 3138 as both a DLNA server and surveillance NVR
Hey there. I'm planning on using a RN3138 as a DLNA server for a new home installation. They will also be installing about 4 or 5 network surveillance cameras. Is is possible to use a single r...
Jan 11, 2018Guru - Experienced User
I think you can get away with one NAS, perhaps with a separate volume for surveillance.
Are the cameras recording 24x7, or are they only recording when they detect motion (or other activity)?
bertmaster
Thanks! Most likely I'll set the cameras up to record on motion.
- StephenBJan 12, 2018Guru - Experienced User
In that case there should be no problem with performance, even if they share the same data volume.
- bertmasterJan 12, 2018Aspirant
Thank you for the info. I've used this NAS before, but just as a file server. Works great.
However, I wasn't sure about running multiple apps.
Thanks again for the quick responses :)
- Nov 24, 2016Retired_Member
