bertmaster
Jan 11, 2018Aspirant
ReadyNas 3138 as both a DLNA server and surveillance NVR
Hey there. I'm planning on using a RN3138 as a DLNA server for a new home installation. They will also be installing about 4 or 5 network surveillance cameras. Is is possible to use a single r...
bertmaster
Thanks! Most likely I'll set the cameras up to record on motion.
Jan 12, 2018Guru - Experienced User
In that case there should be no problem with performance, even if they share the same data volume.
- Nov 24, 2016Retired_Member
