rekent
May 24, 2024Aspirant
ReadyNAS 3138 Loses Network Connectivity
I have a rack mounted ReadyNAS 3138 with LAN ports 1 and 2 connected to a UniFi switch via LAG. Today, the NAS lost network connectivity. I tried power cycling, changing the ports, and changing cab...
Sandshark
May 25, 2024Sensei
Have you installed anything that would need to change/add network configuration files? If you have, and a file associate with it has become corrupt, that could cause the Ethernet mounting to fail to complete. Those files would not be touched by an OS re-install. See also if you get a connection in Support mode (see How-do-I-access-the-boot-menu-on-my-ReadyNAS-2304-3130-or-3138-storage-system ). If you get a connection, then try to telnet in as user root and password infr8ntdebug. If that works, it's your gateway for debugging, but exactly where to look for the problem I don't know.
