iota5
Sep 27, 2019Aspirant
ReadyNAS 3138: very slow sync, and disk tray green fault lights stay on after adding two new drives.
Purchased ReadyNAS RN3138 (4-drive bay rackmount) in May; initial Netgear support just expired. Initially had installed two WD Gold 6TB drives with default X-RAID with no problems. Just added two W...
Sandshark
Sep 27, 2019Sensei
A sync touches every sector, used or not, so your sync time is not unusual, and possible too short. The manual seems inconsistent on the meaning of the LEDs. But I believe the top should be solid green and the bottom blinking/solid green to indicate activity and red for a fault. Your NAS would have needed to do three re-syncs: One of the first drive added to the orignal two, a second of the second drive added to the first three, then a then an expansion using the additional space of the two new ones. Are you sure all the syncs are done?
- iota5Sep 28, 2019Aspirant
The top disk tray LED is a soft green on all four drives, and I believe this is normal. On the two new drives, it's the lower LED's which have been solid bright green even since I inserted the drives in the NAS. The hardware manual only lists three possibilities for the bottom LED: blinking green, off, or solid red.
I was not aware of a third sync, but the NAS seems to be done with syncing. I might have made a mistake when I added drive #4 while drive #3 was still syncing after about 36hours. Then the NAS announced that #3 was done a few hours after I inserted #4, and then #4 began to sync and took about the same amount of time as #3. I could not find in the manual whether to insert two new drives at the same time or sequentially.
If the bright green LED's stay on, I might move my data while it's still limited in size and then reformat all four drives and start over with 4 drives from the beginning.
- SandsharkSep 28, 2019Sensei
When you are adding drives, adding one while another is syncing is fine. It doesn't make things go any faster or slower, but it does eliminate the wait time if you aren't present to instert the second when the first one completes sync. I don't know why re-formatting the drives would make any difference when it comes to the LEDs., but a re-boot could, I suppose.
When a drive is syncing, the access blinking can be so fast that it appears solid. The Volumes page should indicate if any syncing is still ongoing. mdstat.log in the log .zip file will show you a bit more about the status (or issuing cat /proc/mdstat from SSH)..
- iota5Sep 29, 2019Aspirant
Thanks for all the useful information. I've rebooted several times without any change in the two bright green lower LED's. The volumes page indicates a normal state, and the bar at the top about syncing in progress is long gone. Good to know that starting over with four freshly reformatted drives is not likely to help. Maybe I won't bother with that. I'll check the log you suggested to see what's there. Maybe all is well, but those two bright green lights just bug me.
Anyway, thanks for all the useful comments. I'll update the thread if I find out how to turn those LED's off.
