Enlil
Feb 14, 2021Aspirant
ReadyNAS 314 - root volume 99.67% full - cannot connect
My ReadyNAS 314 recently stopped booting at 86%. I performed a disk test through the boot menu. Now it boots but I cannot connect to it via the web interface nor via SSH. RAIDar shows the system as healthy. I did a firmware reset, but nothing changed. I restarted in support mode, but still SSH keeps getting `connection refused`. When I try to access the webiste, I get a 404 fir the /admin page.
- SandsharkSensei
When the root volume gets too full, some configuration files can get corrupted and temporary files cannot be created. The system was probably warning you for a while that this was happening, and you shouldn't have ignored it if it was. There are a couple things that can fill it rapidly, though.
Do not attempt an OS-reinstall or USB recovery. They will just make it worse.
If you are comfortable with the Linux command line, you can go in and find and delete what has filled the OS partition using the support mode boot option. You'll also want to figure out what caused it and fix that, since it will likely just happen again. Plex is one notorious thing that can cause this, BTW. You can find multiple posts on that on the forum. Just don't rely on the internal search engine, as it's abominable. Search using Google.
If you are not comfortable with that, then Netgear paid support is your best bet.
- EnlilAspirantThanks for your response, Sandshark!
I'm pretty certain that I know what process filled up the drive. I cleaned up previously and thought I had disabled it, but must have gotten that wrong.
My biggest issue right now is how I get cli access to the system. As I said in three original post, SSH gets refused and the admin page gives me a 404- SandsharkSensei
So, did you do a search for the answer as I suggested?
You have to go into tech support mode via the boot menu and then you can telnet into the NAS. The user name is root, the password is infr8ntdebug.
At that point, you are in a very stripped down version of the OS. You first need to mount the OS partition.
# start_raids
# btrfs device scan
# btrfs fi show
# mount /dev/md0 /mntFrom there, the steps you took to free space via SSH should work. If configuration files have been corrupted, that may not fully fix the problem, though.
