PWS442
Sep 07, 2018Guide
ReadyNas 314 disk recommendations incorrect
The site recommends a Seagate 6TB IronWolf NAS SATA Hard Drive 6Gb/s 256MB Cache 3.5-Inch Internal Hard Drive for NAS Servers, Personal Cloud Storage (ST6000VN0033). Well, I just received 5 of them f...
- Sep 10, 2018
PWS442 wrote:
I ordered 5 of these yesterday: WD Red Pro 8TB 3.5-Inch SATA III 7200rpm 128MB Cache NAS Internal Hard Drive (WD8001FFWX). Picture seems to incidate they line up the same as the Red Pro 2TB drives I am replacing.
I agree.
FWIW, I use the WD Red 8 TB with the plastic inserts (WD80EFXZ),
PWS442
Sep 07, 2018Guide
Well, I guess I have been lucky in my sequence of upgrades to the NAS over the years. I kind of like the plastic insert, better isolation than metal on metal, IMHO.
But, sigh, thanks for the tip.
Sep 08, 2018Guru - Experienced User
I like the inserts too, but I'm not sure that there's any advantage as far as vibration goes. I still have some older NAS that only use the screws, and drives seem to last in those enclosures also.
FWIW, back in 2013 when the RN314 was designed all drives had those side mounting holes. But as capacity increased, the drive manufacturers were looking for every millimeter of internal space they could get for the larger platters. Holes in the center of the disk got in the way, so they standardized "alternative mount points".
Netgear has adjusted the tray designs since then to better accomodate those new drives. Unfortunately they've chosen not to sell the new trays separately (even though they work perfectly in all OS-6 NAS).
- PWS442Sep 09, 2018Guide
Sheeipshly, he says the screws are "lost". That means they are someplace, but disassociated with my memory! But, marching back to Amazon, I ordered 5 of these yesterday: WD Red Pro 8TB 3.5-Inch SATA III 7200rpm 128MB Cache NAS Internal Hard Drive (WD8001FFWX). Picture seems to incidate they line up the same as the Red Pro 2TB drives I am replacing.
Pity the trays are not available.
Thanks much,
- SandsharkSep 10, 2018Sensei
If you need screws, check Amazon for those intended for SuperMicro servers (with 3.5" drives).
- StephenBSep 10, 2018Guru - Experienced User
I agree.
