aniraghome
Jul 24, 2021Tutor
readynas 314 stopped updating antivirus
Hello all i noticed anti virus definitions were not updated on my ready nas 314 since 6/14/2021. i searched some posts and could not get to a solution that works for me. firmware 6.10.5 hotfi...
- Jul 25, 2021
I will try to write down what to do :-)
1) enable SSH on your NAS (can be done via the gui: system-tab and option setting)
2) on your PC install WINSCP
3) FILE-PROTOCOL: SCP ; HOST NAME: IP-address of your NAS ; PORT NUMBER: 22 ; USER NAME: ROOT ;
(your ROOT-password is the same as your ADMIN-password) ; click LOGIN4) similar to EXPLORER go to directory: /var/lib/clamav/
5) right-click the members (antivir;bytecode;daily;main;mirrors) and choose DOWNLOAD AND DELETE
put/save them somewhere on your PC6) change or go to directory: /etc/clamav/
7) right-click on member freshclam.conf and choose EDIT
8) click after "ReceiveTimeout 120" and hit ENTER
copy/past "TestDatabases false"
member should look like below:DatabaseOwner root
LogSyslog true
LogFacility LOG_LOCAL6
Debug false
MaxAttempts 5
DatabaseDirectory /var/lib/clamav
DNSDatabaseInfo current.cvd.clamav.net
ConnectTimeout 120
ReceiveTimeout 120
TestDatabases false
ScriptedUpdates true
CompressLocalDatabase false
Bytecode true
NotifyClamd /etc/clamav/clamd.conf
OnErrorExecute /usr/bin/clamav_event -s 1
OnUpdateExecute /usr/bin/clamav_event -s 0
Checks 2
DatabaseMirror database.clamav.net
DatabaseMirror db.cn.clamav.net
DatabaseMirror db.tw.clamav.net9) close window in which your are editing freshclam.conf (save it of course)
10) restart your NASHopes this will solve your issue
