dougal83's avatar
dougal83
ReadyNAS 314 US model (swap plug for uk)
Hi
My mate gave me a ReadyNAS 314 and it has a US plug. Would there be a problem if I bought a UK equivalent power cable and just plugged it in? If that would work without blowing up the device where could I purchase the cable? Any links appreciated other than lmgtfy.com :)
Thanks in advance for your advice.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Just connect a standard UK PC power cable to the power brick that shipped with the NAS. You might have a spare one lying around that you used to use to connect a monitor or PC to your wall outlet.
    The PSU is auto-sensing.
ProSupport for Business
