jsdeprey
Jan 04, 2015Aspirant
ReadyNAS 316 and Seagate ST5000DM000 5TB drive
I know this drive is not on the compatibility list, but they seem like a good deal and wondering if anyone had trying them yet. The 4TB of this same drive is on the compatibility list "ST4000DM000" s...
Jan 05, 2015Guru - Experienced User
Likely it will work, but if it is not on the HCL when you need support, netgear would probably deny support.
Personally I'd suggest the WD EFRX series or the Seagate VN (nas) drives instead. They have better manufacturer warranties, and are intended by seagate/wdc for home NAS use. They usually are just a bit more expensive, but in my opinion the 3 year warranty makes up for that.
