HeatherABC
Nov 04, 2015Apprentice
ReadyNAS 316 Worth Purchasing?
Newegg has a deal where I can purchase the ReadyNAS 316 and a 4tb drive for $558. This seems like too good of a deal to pass up. Currently I'm using a Dell PC as a media server (Plex/Kodi) and have ...
Nov 04, 2015Guru - Experienced User
It is one of the Os 6 platforms - which is the most recent ReadyNAS OS. So I think it is a safe purchase. However, I don't work for Netgear and I have no inside info on upcoming launches.
If you plan to run plex, another option would be the RN214 (which was just released). But at current newegg pricing, the RN316 is a better deal.
- HeatherABCNov 04, 2015Apprentice
At this point I don't plan to run Plex from the NAS... though that could be a possibility in the future. I'm going to still run it from the Dell (I have a backup server running on my iMac also). I do worry about the speed of transfer of the media files from this system. I guess I'm still just a bit confused over NAS systems. I'm quite the geek when it comes to technology, but hot swappable NAS systems are still new to me and I'm working to figure out what I want out of it beyond storage... and backups.
- StephenBNov 04, 2015Guru - Experienced User
Several apps are available, but limiting it to storage/backup is a fine approach.
Apps can be found at http://apps.readynas.com/pages/ and https://rnxtras.com/ Its important to realize that most of these are third-party apps, and Netgear doesn't warrant that they work (and doesn't provide support for them).
Plex tends to run slower on the NAS (particularly library updates), and full HD transcoding might stutter/stall. The benefit is that you don't need to leave the PC running 24/7.
Thanks!
Right out of the gate I will not have any redundancy running, I have only a 4tb and 5tb drive to install into the 316. If I later add another 4 and another 5tb drive will I be able to span those to become backup drives for the earlier installed drives? Or will I lose the data on those existing drives?
I don't really understand raids completely as I've never used them. My backup systems to date have simply been OS based such as TimeMachine.
- meverzNov 04, 2015Apprentice
The speed of transfer should be fine (unless you are sending stacks of data). My RN104 can hit about 20-25MB/s write, and upto 70-80 MB/s read.
If it is just for streaming media via plex, I can have 3-4 kids all using plex on their iPads at the same time, with no noticeable slowdown. (Although the Plex Media Server runs on my HTPC macmini, not o nthe NAS).
If the NAS will only be effectively working as a File Server, you can probably get awya with a RN104. I have been very happy with mine, and for the price, it really can't be beat.
My RN102 is in jbod mode, and does ~50 MB/sec write and 70 MB/sec read.
The RN102 has worked out ok for me, but there are a lot more problems with the RN100 series reported here than there are for the higher end models. Plus it is a poor choice if you want to host the plex server on it. It's inability to transcode is a huge drawback for plex.
The RN300 series also has lifetime chat support.
If you can afford the RN316, its a better choice.
I'd set up in jbod, not RAID-0 (giving you two volumes).
The expansion options are in the user guide: http://www.downloads.netgear.com/files/GDC/READYNAS-100/readynas6.2_11March2015.pdf - see page 33 and following. If you start with 2 jbod volumes, you can expand them to two RAID-1 volumes w/o losing data.
Another option (more space efficient) is to destroy the 5 TB volume, switch to xraid, and then expand (adding smallest disks first). The smallest disks that can be added would be 4 TB. You'd keep the data on the 4 TB volume, but would need to reload the 5 TB contents from backup.
One last tip - if you use the NAS for primary storage, make sure you have independent backups. RAID is useful, but it not enough to protect your data.
- HeatherABCNov 05, 2015Apprentice
Really? I thought that was the main reason for using RAID and giving up storage space to do so? Now I'm really confused. Why wouldn't I just make backups rather than using RAID? What's the benefit?
I think I need to go find RAID for dummies.
- meverzNov 05, 2015Apprentice
RAID is for redundancy. So if a disk fails, you can keep working without losing any downtime. Depending on the amount of data, it can be quicker / easier to recover from a disk failure. Just swap the disk, and wait for the resync. No need to track down the (offsite) backup, or wait for it to download from the cloud. You can continue with very little down time.
But a RAID array won't help you if your ReadyNAS unit dies, or if your house burns down, or if the entire unit is stolen. That is why you need a backup. A backup will also cover you if you have a disk die during a resync, or if you accidentally delete a file.
RAID and backups are complementary.
