Naversten
Feb 02, 2011Aspirant
ReadyNAS 3200
I'm about to buy a ReadyNAS 3200. I want two things in place before I buy: a) possibility to utilize 3TB-disks. I want to make sure that the hardware will not impose restrictions. Will there for su...
mdgm-ntgr
Feb 02, 2011NETGEAR Employee Retired
Naversten wrote:
Just want to make sure; do I need to wait for BOTH 4.2.16 AS WELL AS some LSI firmware update - or will the 4.2.16 incapsulate any needed LSI firmware?
Don't know. I think 4.2.16 would include the necessary update but we'll have to wait and see what NetGear will come up with.
Naversten wrote: Will that be included in the 4.2.16 update - or is that update further away? If so - I will HAVE to fill all twelve slots from start to avoid factory reset. Or wait until future update...
I think the 16TB limit will likely still be there in 4.2.16. It is in the current public beta. So we'll have to wait and see what happens. As of 4.2.16 Flex-RAID volumes are expandable so using multiple Flex-RAID volumes is another option to consider.
