Anton_
Dec 04, 2022Tutor
ReadyNAS 4 Ultra OS 6.10.8, any fix for the fan control?
Running ReadyNAS os 6.10.8 and also replaced the loud fan. The fancontrol worked with the defaul OS. After upgrading to OS6 the fan control stopped working. Nothing happens when chosing silent, bal...
Sandshark
Dec 05, 2022Sensei
At least for the standard fan, that issue was solved a very long time ago. And the only issue I've seen before on the boards with a replacement fan is one with a higher stall speed, so the fan min speed control parameter needs to be tweaked.
- Anton_Dec 05, 2022Tutor
Aha!
I saw a thread on adjusting /etc/fancontrol with other values for Ultra 4 as i have. And there was other models too.
Might be needed then. - Anton_Dec 05, 2022Tutor
As i wrote in my post the GUI didnt change the fan behavior with the original fan either.
Full speed all the time. But with old OS4 the GUI was working to change the fan behavior/profile.
So there need to be done some manual config or install additional packages to get it working.
I can se the fan min and target speeds for the "fan1" and the min are 400 and the target 1800- Anton_Dec 05, 2022Tutor
Is it possible to try and control the fan manually with a command?
Or are fancontrol and lm-sensors or such needed to be installed?
Ive seen that readynasd reported my NAS as ReadyNAS
08/23/2011 ReadyNAS-NVX-V2 V1.10
