Anton_
Dec 04, 2022Tutor
ReadyNAS 4 Ultra OS 6.10.8, any fix for the fan control?
Running ReadyNAS os 6.10.8 and also replaced the loud fan. The fancontrol worked with the defaul OS. After upgrading to OS6 the fan control stopped working. Nothing happens when chosing silent, bal...
Sandshark
Dec 05, 2022Sensei
At least for the standard fan, that issue was solved a very long time ago. And the only issue I've seen before on the boards with a replacement fan is one with a higher stall speed, so the fan min speed control parameter needs to be tweaked.
Anton_
Dec 05, 2022Tutor
Aha!
I saw a thread on adjusting /etc/fancontrol with other values for Ultra 4 as i have. And there was other models too.
Might be needed then.
