Anton_
Dec 04, 2022Tutor
ReadyNAS 4 Ultra OS 6.10.8, any fix for the fan control?
Running ReadyNAS os 6.10.8 and also replaced the loud fan. The fancontrol worked with the defaul OS. After upgrading to OS6 the fan control stopped working. Nothing happens when chosing silent, bal...
Anton_
Dec 05, 2022Tutor
As i wrote in my post the GUI didnt change the fan behavior with the original fan either.
Full speed all the time. But with old OS4 the GUI was working to change the fan behavior/profile.
So there need to be done some manual config or install additional packages to get it working.
I can se the fan min and target speeds for the "fan1" and the min are 400 and the target 1800
Anton_
Dec 05, 2022Tutor
Is it possible to try and control the fan manually with a command?
Or are fancontrol and lm-sensors or such needed to be installed?
Ive seen that readynasd reported my NAS as ReadyNAS
08/23/2011 ReadyNAS-NVX-V2 V1.10
- StephenBDec 05, 2022Guru - Experienced User
08/23/2011 ReadyNAS-NVX-V2 V1.10That wouldn't be an Ultra-4. Is there an RND4000 part number on the ReadyNAS?
- Anton_Dec 05, 2022Tutor
Yes, it says RNDU4000 as model on the back plate 🙂
- mdgmDec 05, 2022Virtuoso
Anton_ wrote:Ive seen that readynasd reported my NAS as ReadyNAS
08/23/2011 ReadyNAS-NVX-V2 V1.10That is the latest BIOS for the Ultra 4.
- Anton_Jan 02, 2023Tutor
The new fan spins down within half a second and then turns full blast on NAS booting.
So i guess the system does something with the fan.
I just cant figure out how to control the fan since Silent, Cool and Balanced does not work.
PWM_MIN and all those seems correct.
Maybe i need to post in another sub topic?
ReadyNAS users or such..
