theJonson
Jun 16, 2010Aspirant
ReadyNAS 4200 + 10GBe Option
I've been looking into the 10GBe option on the ReadyNAS 4200 to upgrade our HyperV system to a failover cluster. All I can find is that if you buy the 4200 with the 10GBe option you get 2x 10GBe CX...
ReadySECURE
Jun 28, 2012Apprentice
Chances are high that it will work. The supported deployment would be to use a Netgear connector along the lines of the AXC763.
