theJonson
Jun 16, 2010Aspirant
ReadyNAS 4200 + 10GBe Option
I've been looking into the 10GBe option on the ReadyNAS 4200 to upgrade our HyperV system to a failover cluster. All I can find is that if you buy the 4200 with the 10GBe option you get 2x 10GBe CX...
mataglap
Jun 28, 2012Aspirant
readysecure1985 wrote: Chances are high that it will work. The supported deployment would be to use a Netgear connector along the lines of the AXC763.
Ah, that gets interesting, thank you. Is there any certification of interoperability with that cable/transceiver and Cisco kit (specifically a OneX Converter Module from the Netgear side? Or whom should I contact about that because I understand it's not really a ReadyNAS specific issue. (For some of the Cisco Nexus devices, Cisco documents that some twinax cables from NetApp, EMC, &c. work, but not any from Netgear.)
