theJonson
Jun 16, 2010Aspirant
ReadyNAS 4200 + 10GBe Option
I've been looking into the 10GBe option on the ReadyNAS 4200 to upgrade our HyperV system to a failover cluster. All I can find is that if you buy the 4200 with the 10GBe option you get 2x 10GBe CX...
mataglap
Aug 30, 2012Aspirant
Is there anyway to get a statement about compatibility of the CX4 interface with non-Netgear CX4 cables and non-Netgear CX4 switch ports at the other end? It has to plug into a Cisco X2 port, which looks for a Cisco cable.
