egoff
May 10, 2012Aspirant
ReadyNAS 4200 part numbers--???
I'm trying to figure out the differences between the various part numbers for the 12 TB ReadyNAS 4200: RN12G0620, RN12S0620, RN12T0620, RM12T1210... If you look at these on netgear.com and go to Produ...
ReadySECURE
May 10, 2012Apprentice
The 0620 means six drives that are 2TB each. The 1210 means twelve drives that are 1 TB each.
The G means Two 10/100/1000 Ethernet ports with load balancing and failover with 2 CX-4.
The S means Two 10/100/1000 Ethernet ports with load balancing and failover with 2 SFP+.
The T means Two 10/100/1000 Ethernet ports with load balancing and failover.
As for the SFP+ modules, they aren't included with the 4200. The part numbers for them are AXM761 AXM762 and AXM763.
I hope this helps. :)
