dannieboiz
Jul 24, 2014Tutor
ReadyNas 4200 V2 processor
Can someone tell me what processor does the ReadyNas 4200 V2 have and how many gb of RAM? Thinking about picking one up to play around with. Since the board looks like a standard ATX with Xeon pro...
mdgm-ntgr
Jul 24, 2014NETGEAR Employee Retired
Are you sure it is a v2, not a v1?
Do you have physical access to the unit?
We do not support running a 3rd party OS on any of our units. Having said that it is possible.
You may also wish to consider the new RN4220 which runs ReadyNAS OS 6 which uses the BTRFS filesystem or the ReadyDATA 5200 which uses ZFS.
