dannieboiz's avatar
Jul 25, 2014
ReadyNas 4200 V2 processor
Can someone tell me what processor does the ReadyNas 4200 V2 have and how many gb of RAM?
Thinking about picking one up to play around with. Since the board looks like a standard ATX with Xeon processor can someone just drop a different OS like Linux/Windows etc.. on there?
  • I wouldn't advise unplugging the fans, but maybe replacing them, if that's standard ATX with standard processors there is a chance that these are standard fans too. (I don't know that model, just guessing here)
    I would advise against tossing the sinology too. You never know what could happen, having a device and a backup device is a good plan. I also don't know if the 4200 is subject to the 16Tb volume limit and the 8Tb expansion limit or not.
    If you ever want to drop a windows on it, you may want to check that drivers are supported. But a debian shouldn't be a problem.
  • StephenB's avatar
    All 4.2.x systems are subject to the 16Tb volume limit and the 8Tb expansion limit. Personally I'd use flexraid on a 12 bay system. 12 disk raid5 or raid6 arrays are possible of course, but in my opinion you are much better off with smaller arrays (say 6 disks or less).
    By the time I'm done tonight, I will have migrated all 6 drives to the RN, 2x 1tb, 4x 2tb. I want to have dual drive redundancy so I'm going to break the xraid 2 and convert it to FlexRaid raid 6 as some suggested here.
    should this give me 6Tb? I'm reading that Raid 6 will give me 4Tb with 4Tb unusable.
    Assuming I'm going to add only 3Tb drives to the unit from this point on, by the time I get to 12 disk I'll end up with 20Tb. Why are you recommending 6 disk or less? Mainly for reliability I suppose?
    In the next 5 years, I can only see my critical data growing to 10Tb of which I'm backing up to Carbonite as well as a remote server daily.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Using X-RAID2 dual-redundancy you would get 6TB (two RAID-6 layers - 6x1TB and 4x1TB layers).
    Using Flex-RAID RAID-6 you'd get a 4TB volume.
ProSupport for Business
