Dochide
Aug 21, 2015Aspirant
Readynas 4200 v2 specs
I have the opportunity to buy a ReadyNAS 4200 v2, no 10Gbit ethernet for around $1500 with 6x 4TB drives. I believe the model is an RN12T1210. The owner doesn't know the specs on the device. I am loo...
- Aug 21, 2015
Dochide wrote:
Yeah, that was all the information I could find as well. I didn't think about the volume limits, but if I add more drives I can just use the first 6 as volume one at 16tb with two drive redundancy and the next 6 as the same correct? Or does that limitation apply without the parity drives included?
Also, as a side not to maybe get around the limitations, could another OS be installed? Something like FreeNAS? I know it wouldn't be supported, but the 4200v2 is already past the end of life support anyway.
The XRAID expansion limits apply to the volume size, not the raw capacity. If you use flex-raid, you can set up multiple volumes (which I would recommend anyway, I personally wouldn't want 12 drives in a single array).
You can probably switch over to OS-6 (certainly pro and ultra owners have). There are instructions here - and it would be simpler than FreeNAS. OS6 uses btrfs instead of ext4, and it doesn't have the expansion limits.
Dochide
Aug 21, 2015Guru - Experienced User
