dbrown_victoria
Jan 05, 2012Follower
ReadyNAS 4200
i'm considering a readynas 4200 for backup storage, some video/picture storage in an enterprise environment. i am finding it difficult to get clear information about the readynas & would like to p...
TeknoJnky
Jan 05, 2012Hero
dbrown@victoria.ca wrote: i'm considering a readynas 4200 for backup storage, some video/picture storage in an enterprise environment.
i am finding it difficult to get clear information about the readynas & would like to post some questions.
- how many snapshots can i have at one time?
1
- will a large number of snapshots adversely affect performance?
since only 1 snapshot is active, I don't think it effects performance at all
- are the snapshots visisble to all users, or can access to the snapshots be permissioned?
snapshots are accessed via 'sharename-snap', they should have the same permissions as the original
- we would need to replicate the data to a 2nd offsite readynas, will the rsync replication retain all ntfs permissions on files/folders?
good question, not sure but I would suspect so
- will the replicated data be able to retain the snapshots of the 1st readynas?
you do not replicate the snapshot itself, only the data that is frozen in the snapshot, so no
- is there email notification of any equipment (disk/psu/etc.) failures
yes and you can configure alerts within frontview
- is there email notification of disk usage or warnings when getting close to full?
yes, ditto above
