Pumpir
Jul 11, 2018Aspirant
ReadyNAS 422 - SMB share and MacOS
ReadyNAS 422 with 6.9.3
Creating SMB share "test-share" (SMB), adding R/W permissions for "user1" and "user2".
Computer 1 - Win10: user1 connected to test-share
Computer 2 - MacO...
Jul 11, 2018Guru - Experienced User
Have you tried AFP on the MacOS system, and see if it behaves the same way?
Pumpir
No, not testing this behavior with AFP, because AFP is generating another issues while working with files from MS Office 2011 on network share .
- StephenBJul 11, 2018Guru - Experienced User
I'm not a Mac user, but I have occasionally seen stale file lists in file explorer (more common with SSD disks in the PC than with the NAS though). But your case looks different, because the Mac shows an up-to-date folder to the user (without the deleted file), but then gets confused when you try to do the copy.
Do you have a way to test if this also happens with 2 Macs or 2 PCs?
Also, I suggest toggling the strict-sync setting for the test share, and perhaps also the enhance MacOS setting too.
- PumpirJul 11, 2018Aspirant
Between 2 Macs it is the same issue (does not matter, which computer deleted the file), Mac is showing in Finder that file has disappeared, but when trying to copy the file back, issue is there. I was experimenting with strict sync and Enhance MacOS (after each change remounting share on Mac), but no effect. I was reading many articles about poor qualitty of SMB implementation in Mac, but noone is offering some solution (certainly solution would be not to use MacOS, but this is decision of my bosses). Access from Win OS is significantly faster and without any problem.
Hopefully someone else with a Mac environment (ideally Netgear) will try to reproduce what you are seeing.
Another thought: You could set up a test network share on the Windows PC, and see if the problem also happens there.
