kclau
Aug 14, 2019Follower
ReadyNAS 422 and php
Hi, I am going to buy a ReadyNAS 422. Before the purchase, I would like to know: - which version of PHP is pre-installed on the NAS? - if PHP is not pre-installed, which version is available in...
Aug 15, 2019Guru - Experienced User
kclau wrote:- which version of PHP is pre-installed on the NAS?
It's not installed.
kclau wrote:- if PHP is not pre-installed, which version is available in the ReadyNAS Apps? Are both 5.6 and 7.x available for download?
You can get an tested install package for 7.2.21 from https://rnxtras.com/addons/php-7-2-rnos-6. There is a small cost (€2.99), but the developer provides installation support.
