scottonaharley
Dec 19, 2016Aspirant
ReadyNAS 4220 NFS configuration
I'm trying to use some NFS shares for a virtual machine environment. It requires the following configuration: Change the ownership of the export directory, replacing directory_name with the name...
scottonaharley
Jan 04, 2017Aspirant
While that appears to be a solution since it is executed at the command line and modifies the o/s it would eliminate the availability of support. Since OVIRT (Red Hat Enterprise Virtualisation is the OVIRT code base so it has the identical issue) is growing by virtue of Red Hat's implementation we are hopeful that Netgear will recocognize the need to support it for all users rather than view this as a isolated user problem. Otherwise netgear storage won't be an option for anyone implementing RHEV
YeZ
Jan 06, 2017NETGEAR Expert
Thank you for the message. Yes, we are reviewing this request internally and likely will implement the option.
- scottonaharleyJan 26, 2017Aspirant
Is there any way that we can be advised as to the status of this issue?
- mdgm-ntgrJan 30, 2017NETGEAR Employee Retired
We're still looking into it. Hopefully when a relevant change is added it would be mentioned in the Release Notes.
- scottonaharleyApr 16, 2017Aspirant
Has there been any movement on this topic?
