scottonaharley
Dec 19, 2016Aspirant
ReadyNAS 4220 NFS configuration
I'm trying to use some NFS shares for a virtual machine environment. It requires the following configuration: Change the ownership of the export directory, replacing directory_name with the name...
YeZ
Jan 06, 2017NETGEAR Expert
Thank you for the message. Yes, we are reviewing this request internally and likely will implement the option.
scottonaharley
Jan 26, 2017Aspirant
Is there any way that we can be advised as to the status of this issue?
- mdgm-ntgrJan 30, 2017NETGEAR Employee Retired
We're still looking into it. Hopefully when a relevant change is added it would be mentioned in the Release Notes.
- scottonaharleyApr 16, 2017Aspirant
Has there been any movement on this topic?
