EagleTRL's avatar
EagleTRL
ReadyNAS 424 Swapping disks
I am new to the ReadyNAS appliances - and NAS in general, so excuse if this is real basic.   I bought a RN424 and loaded it with three used disks just to test it out before committing with "real" N...
  • StephenB's avatar
    Nov 14, 2019
    EagleTRL wrote:
    Since the two 1TB drives are older, I would like to run some tests on them.  I noticed that there is an option for "Disk Test" under the System:Volume tab, but I can not find any documentation on it.  I ran the process, and got messages that the disk test had started and finished, but I can not find where the results are displayed.
    It runs the long disk test using smartctl.  Download the log zip file from the web ui, and look in disk_info.log - that has all the SMART stats.
ProSupport for Business
