drsox
Jun 29, 2020Guide
ReadyNAS 424 UPS compatibility.
I was using APC RS 1500 UPSs with my 2x ReadyNas 424 (there are a hold-over from the Pro6 units I used to have). They have always been incompatible with the 424s (can't use the auto-shutdown etc).
One of the UPSs has now failed and I would prefer to find a model that is compatible (can't find a list anywhere).
Any suggestions or, better still, point me to the official list. APC preferred as I have used them w/o issues for 10 years or so.
Thanks.
1 Reply
There is no list here.
The NUTS folks do have one here: https://networkupstools.org/stable-hcl.html
Models with USB output should be compatible though.
