carlpea's avatar
carlpea
Tutor
Oct 27, 2024
ReadyNAS 426 - Failed drive ok after re-insert and RAID rebuild
Hi All,
Had an odd occurance this weekend where one drive was reported as 'Failed', however after pulling the drive and re-inserting the array fully rebuilt (24 hours +) and the drive shows as no issues:
Anyone had anything similar?
I'm looking to purchase a spare drive in the event it occurs again, however, it seems odd that there are no errors reported on the drive itself:
1 Reply
  • StephenB's avatar
    Download the full log zip file, and look in there for disk and btrfs errors.
    After you have the logs, perhaps run the disk test from the volume settings wheel.
ProSupport for Business
