Dwrws
May 17, 2024Aspirant
ReadyNAS 4312 Not pinging
I have readynas 4312 i am not able to ping the NAS also not able to find the NAS on Raidar software
Dwrws wrote:
I have readynas 4312 i am not able to ping the NAS also not able to find the NAS on Raidar softwareWhat happens if you power down, remove the disks, and power up again?
Normally when you do that, you would be able to ping the NAS, and RAIDar would find it with a no disks status.
Label the disks by slot as you remove them, so you can easily restore them to the same slot after this test. Make sure the NAS is powered down when you put them back.
- DwrwsAspirant
all disks are removed and power up the NAS but still the same problem, NAS is not pinging. Raidar also not finding the NAS
