Doblerm
Apr 22, 2020Aspirant
ReadyNas 4312x surveillance video storage issue
We installed a ReadyNas RR4312X with 12x 6TB Seagate SkyHawk Surveillance drives in RAID-50 for Avigilon security camera storage. We started out with 55 cameras and it worked flawlessly but as we are now approcahing 110 cameras it is starting to become sluggish and have issues reading data simultaneous to writing it. It is not a bandwidth issue as we have one of the 10Gb links dedicated to incomming traffic and the other 10Gb to outgoing. Respectively they are only showing 750MBps into the unit and 400MBps out. I am leaning towards this being a disk I/O issue however each drive has a data transfer rate of 600MBps and an internal rate of 195MBps.
So the question is am I on the correct path of troubleshooting or should I be looking at a configuration issue? All ideas are appreciated.
Thanks,
Mike
I am wondering what the needed peak write throughput is, and also the amount of data being collected per day.
Using multiple volumes might help, as seeks would be independent. If you are writing to shares (as opposed to LUNs) then using SSDs for metadata tiering and possibly data caching might also help. Either approach would require using bigger physical disks to keep the same capacity.
You might also look at the CPU load in the performance graphics. RAID-10 would likely reduce the CPU load, since no parity computations would need to be done. It would also reduce the amount of disk I/O needed for writes.
- DoblermAspirant
Thanks for the fast reply StephenB ,
We are a school so the money simply isnt there for SSD drives. Currently we are maxing out the storage with the desired retension rate so changing to RAID 10 would further limit retension unless like you stated we went to larger drives.
I didn't see a CPU performance section. Unfortunately we have been closed for the last 5 weeks (spring break and COVID-19) so the 30-day chart is not represenative of average usage and I am unable to pull specific numbers.
Do you have ssh access remotely? If you do, then you can just run top.
- Nov 24, 2016Retired_Member
