kentd
May 09, 2017Tutor
ReadyNAS 516 just upgraded to 6.7.1 and data volume has not loaded
Hi, I just installed 6.7.1 and on re-boot the primary data volume has not loaded - and suggests removing the inactive volume. I have two volumes, one of 6 drives in the RN516, this was a raid 6 vol...
- May 16, 2017
/data-0/.timemachine was a subvolume, so a regular deletion didn't work. I removed the subvolume and directory, and now everything is mounted normally.
kentd
May 09, 2017Tutor
Is there any instructions or link to how please?
kentd
May 10, 2017Tutor
Last login: Sun Jul 3 18:55:46 2016 from 192.168.7.180
root@KDNAS4:~# df -h
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 3.7G 25M 100% /
tmpfs 1.9G 0 1.9G 0% /dev/shm
tmpfs 1.9G 4.0M 1.9G 1% /run
tmpfs 960M 1.1M 959M 1% /run/lock
tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
/dev/mapper/eda1-0 17T 11T 6.0T 64% /eda1
/dev/sdl1 1.9G 917M 969M 49% /media/USB_FLASH_5
/dev/mapper/eda1-0 17T 11T 6.0T 64% /var/ftp/Movie1
/dev/mapper/eda1-0 17T 11T 6.0T 64% /var/ftp/TV2
root@KDNAS4:~# df-i
-bash: df-i: command not found
root@KDNAS4:~# df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
udev 490647 653 489994 1% /dev
/dev/md0 0 0 0 - /
tmpfs 491265 1 491264 1% /dev/shm
tmpfs 491265 999 490266 1% /run
tmpfs 491265 25 491240 1% /run/lock
tmpfs 491265 11 491254 1% /sys/fs/cgroup
/dev/mapper/eda1-0 0 0 0 - /eda1
/dev/sdl1 0 0 0 - /media/USB_FLASH_5
/dev/mapper/eda1-0 0 0 0 - /var/ftp/Movie1
/dev/mapper/eda1-0 0 0 0 - /var/ftp/TV2
root@KDNAS4:/# du -csh /var/log/*
4.0K /var/log/alternatives.log
1.5M /var/log/apache2
32K /var/log/apt
4.0K /var/log/btmp
4.0K /var/log/dbbroker.log
124K /var/log/dpkg.log
8.0K /var/log/faillog
6.3M /var/log/frontview
0 /var/log/fsck
71M /var/log/journal
12K /var/log/lastlog
56K /var/log/mysql
0 /var/log/mysql.err
0 /var/log/mysql.log
0 /var/log/news
136K /var/log/proftpd.log
2.0M /var/log/readynasd
260K /var/log/samba
224K /var/log/wtmp
81M total
root@KDNAS4:/# du -csh /var/*
0 /var/agentx
68M /var/backups
51M /var/cache
44M /var/cores
5.8T /var/ftp
80M /var/lib
0 /var/local
4.0K /var/lock
81M /var/log
0 /var/mail
8.0K /var/netatalk
40K /var/nuuo
0 /var/opt
9.6M /var/readynasd
0 /var/replicate
4.0K /var/run
4.0K /var/spool
0 /var/tmp
4.0K /var/www
5.8T total
root@KDNAS4:/# du -csh /var/log/frontview/*
140K /var/log/frontview/amazoncd.log
3.0M /var/log/frontview/amazoncd.log.old
1.2M /var/log/frontview/backup
4.0K /var/log/frontview/initrd.log
164K /var/log/frontview/msmtp.log
4.0K /var/log/frontview/password_recovery.log
460K /var/log/frontview/status.log
1.5M /var/log/frontview/status.log.old
6.3M total
Only apps i currently use are ReadyNAS Surveillance and Transmission.
