kentd
May 09, 2017Tutor
ReadyNAS 516 just upgraded to 6.7.1 and data volume has not loaded
Hi, I just installed 6.7.1 and on re-boot the primary data volume has not loaded - and suggests removing the inactive volume. I have two volumes, one of 6 drives in the RN516, this was a raid 6 vol...
- May 16, 2017
/data-0/.timemachine was a subvolume, so a regular deletion didn't work. I removed the subvolume and directory, and now everything is mounted normally.
kentd
May 10, 2017Tutor
Done
jak0lantash
May 10, 2017Mentor
Did you use the mount command given by StephenB?
mount --bind / /mnt
Then look inside it:
cd /mnt du -d1 -h
It will tell you which is the biggest folder, then cd into it and re-run:
cd <big_folder> du -d1 -h
Repeat the operation until there is no more big folder, only the total is big, which means it's big file(s) in the current directory, then:
ls -lhS
When you're finished cleaning up the big files, unmount the temporary bind:
cd umount /mnt
