kentd
May 09, 2017Tutor
ReadyNAS 516 just upgraded to 6.7.1 and data volume has not loaded
Hi, I just installed 6.7.1 and on re-boot the primary data volume has not loaded - and suggests removing the inactive volume. I have two volumes, one of 6 drives in the RN516, this was a raid 6 vol...
- May 16, 2017
/data-0/.timemachine was a subvolume, so a regular deletion didn't work. I removed the subvolume and directory, and now everything is mounted normally.
jak0lantash
May 11, 2017Mentor
"df -i" is irrelevant on a RN516 as both the data volume and the OS volume use BTRFS.
Does it boot now? Is your data volume blue?
kentd
May 11, 2017Tutor
Hi, the unit reboots but the primary data volume is still not loading.
Is it because its not md126, or because it is encrypted too? (yes the USB with the encryption key is still in - and hasnt been removed)
- kentdMay 14, 2017Tutor
jak0lantash StephenB mdgm-ntgr can anyone please advise next step? is there a way to recover/reboot the data volume?
