kentd
May 09, 2017Tutor
ReadyNAS 516 just upgraded to 6.7.1 and data volume has not loaded
Hi, I just installed 6.7.1 and on re-boot the primary data volume has not loaded - and suggests removing the inactive volume. I have two volumes, one of 6 drives in the RN516, this was a raid 6 vol...
- May 16, 2017
/data-0/.timemachine was a subvolume, so a regular deletion didn't work. I removed the subvolume and directory, and now everything is mounted normally.
kentd
May 16, 2017Tutor
NASguru wrote:
kentd wrote:
Skywalker wrote:rm -rf /data-0confirmed nothign i need in there, it has ./.timemachine and ./Amazonclouddrive - neither of which are required.
i mounted it as mnt, cd/mnt into it, and then tried your remove command:
Ken, did you get your volume missing issue resolved. If so, what was the solution? I too run a backup job from one NAS to another and wonder if it wrote some data to the root volume by mistake which resulted in my issues?
Not yet, mdgm-ntgrand Skywalker have the tech support code - so hopefully they can remove that folder from root and it will bring back my regular data volume.
Skywalker
May 16, 2017NETGEAR Expert
- SkywalkerMay 16, 2017NETGEAR Expert
kentd wrote:Thanks so much. Confirmed both volumes are up. Is it goign to survive restarts etc?
Yes, there shouldn't be any issue with restarting or updating.
- kentdMay 26, 2017Tutor
I followed GUI prompts and installed 6.7.3 today, however since then the closest i get to runnings is 'management service is offline' in raidar.
SSH is available.
Logs can't be downloaded from raidar, however the diagnostics shows lots of entries like this:
2017-05-26 19:55:12: transmission-da[5730]: segfault at 4 ip 00007fa98468efa9 sp 00007fa980e22ca0 error 6 in libc-2.19.so[7fa9845d9000+1a1000]root@KDNAS4:/mnt/var# df -h
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 1.5G 0 100% /
tmpfs 1.9G 0 1.9G 0% /dev/shm
tmpfs 1.9G 33M 1.9G 2% /run
tmpfs 960M 12K 960M 1% /run/lock
tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
/dev/mapper/eda1-0 17T 12T 4.6T 73% /eda1
/dev/mapper/data-0 11T 7.2T 3.8T 66% /data
/dev/mapper/data-0 11T 7.2T 3.8T 66% /home
/dev/mapper/data-0 11T 7.2T 3.8T 66% /apps
Any ideas please?
- mdgm-ntgrMay 26, 2017NETGEAR Employee Retired
If you have updated to 6.7.3 and ran into this issue please try USB Boot Recovery with ReadyNAS OS 6.7.4 which is now available!
If you have not yet upgraded please upgrade to 6.7.4 rather than 6.7.3. If your system has already been fixed I would still suggest updating to 6.7.4 the normal way using the web admin GUI.
