starbuck_
Mar 02, 2014Aspirant
ReadyNas 516 preparation
Hello, after 6 years of using my NV+ I have done it. :D I ordered a new Readynas 516 yesterday. I also ordered 6x the Seagate 4TB NAS drive ST4000VN000. The equipment will arrive in the next few...
Mar 02, 2014Guru - Experienced User
If the system doesn't ship with 6.1.6, then it is fastest to update to 6.1.6 with a single disk, and then do a second factory reset with all disks in place. You can use a smaller scratch disk for the update, that would be faster still.
starbuck_ wrote: Start with 1 drive and update the system to 6.1.6 and then do a reset. After that I can put in all the other drives do a restart and start configuring the system?
No, fortunately that is rare.
starbuck_ wrote: Is a reset needed every time I update the firmware?
It will run the SMART test built into the drive. Usually I run the manufacturer diags (seatools in this case) on a PC before using the drives in the NAS. That is time-consuming, but I'd rather find problems with drives before I install.
starbuck_ wrote: Has the Readynas a function for checking the discs for errors before use?
Yes.
starbuck_ wrote: Can I use xraid2 mode for dual-redundancy ?
Running an NFS backup job on the RN516 over a gigabit network. Then edit the job to rsync, and re-run. That is faster than Windows explorer. I do this one share at a time.
starbuck_ wrote: What is the best way for Transferring the data from the NV+ to the RN516?
