starbuck_
Mar 02, 2014Aspirant
ReadyNas 516 preparation
Hello, after 6 years of using my NV+ I have done it. :D I ordered a new Readynas 516 yesterday. I also ordered 6x the Seagate 4TB NAS drive ST4000VN000. The equipment will arrive in the next few...
starbuck_
Hi StephenB,
Thank you for your answers.
I can't wait to get started with my new ReadyNas 516 ... )
That's good. So I don't need to do a time consuming "backup-reset-restore" thing.
Which test-mode do you use in the Seatools?
-Basic Test ->Long Generic?
Could you please explain how to configure an NFS backup and rsync job in detail?
Thank you for your help.
best regards
starbuck
No, fortunately that is rare.
It will run the SMART test built into the drive. Usually I run the manufacturer diags (seatools in this case) on a PC before using the drives in the NAS. That is time-consuming, but I'd rather find problems with drives before I install.
Running an NFS backup job on the RN516 over a gigabit network. Then edit the job to rsync, and re-run. That is faster than Windows explorer. I do this one share at a time.
best regards
starbuck
