starbuck_
Mar 02, 2014Aspirant
ReadyNas 516 preparation
Hello, after 6 years of using my NV+ I have done it. :D I ordered a new Readynas 516 yesterday. I also ordered 6x the Seagate 4TB NAS drive ST4000VN000. The equipment will arrive in the next few...
vandermerwe
Mar 02, 2014Master
Yes.
I was just pointing out that you don't need to wait for an xraid volume to build before you do the switch to flex raid. You can interrupt it immediately.
In flex raid you select the disks you want in the volume, select raid6 then let it build.
When it's finished you can switch to xraid again. It won't rebuild at this stage.
