gregb_pro
Apr 16, 2013Aspirant
ReadyNAS 516 Questions
Is the ReadyNAS 516 the successor to the ReadyNAS Pro Business Edition? Does the ReadyNAS 516 include all the features of ReadyNAS Pro Business Edition? Is the ReadyNAS 516 the only ReadyNAS model w...
mdgm-ntgr
May 06, 2013NETGEAR Employee Retired
Microsoft will finally be ending support for Windows XP in under a year. It's time to move on to newer versions of Windows.
ReadyNAS OS may/may not work with Windows XP, but even if it does work NetGear would probably be unable to provide support should you encounter issues.
