dunkens's avatar
dunkens
Apprentice
Mar 21, 2018
Readynas 526x 12 tb hds ??
Hi Is there anyone that can confirm that WD Gold WD121KRYZ 256MB 12TB is working with the RN526X ??
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    Hi dunkens
    WD121KRYZ is not listed as compatible under the ReadyNAS HCL for HDDs. Meaning NETGEAR may deny support if the disks used are not listed or tested as compatible under the HCL.
    But regarding if it will work, I can say it will. It's a new model and there's a possibility that the list is not yet updated.
    But if you want assurance, other members might have tried using the same model so it would be better if we can wait for their inputs.
    Hope this helps!
    Regards
    • dunkens's avatar
      dunkens
      Apprentice
      Its been on the market quite some time , is there any eta on the list for the hardware that is working with the 526 ?
      IF something aint working im sitting with 3 x 12 tb and no support :((
      • Marc_V's avatar
        Marc_V
        Hi dunkens
        NETGEAR perform stringent tests before a disk model can be listed as compatible/qualified, I don't have any knowledge on to when the list will be updated.
        It's an Enterprise drive with Vibration protection and that is what NETGEAR recommends as well. Plus the 10TB model (WD101KRYZ) is already listed for 526X so it should be fine too.
        ReadyNAS HCL
        Regards
ProSupport for Business
