Clammy
Apr 18, 2018Guide
ReadyNAS 6 cpu specs
Hello,
I have various ReadyNAS 6 Pro models and I can't find the CPU specs. I remember there used to be a spreadsheet that Netgear had with all the models and their specs. These are older discontinued models so I can't seem to find proper specs or I find varying specs. Does anyone know exactly what CPU they came with or someway to check withouth removing the heatsink and fan?
On a separate note, does anyone know where I can cheapyl buy drive caddies for these?
Thank You!
- JohnCM_SNETGEAR Employee Retired
Hi Clammy,
The ReadyNAS Pro 6 has the 2.66 GHz Intel Pentium Dual Core CPU. You may also check this datasheet as reference.
For the drive caddies, you may try Amazon. I believe it is still being sold there. I occasionally see drive caddies for legacy NAS models being sold on eBay as well. You may also wait for suggestions on where you can you buy a cheaper drive caddy from other community members as well.
Regards,- ClammyGuide
Hi John,
Do you know exactly which CPU model they came with?
I also have an RNDP6000. Does that have the same CPU or the atom version?
Thank you!
Hi Clammy,
The RNDP6000-100 uses the E2160 1.8Ghz while the RNDP6000-200 uses the E5300 2.6GHz. Both NAS models use Pentium CPUs. You can also check the CPU model on the NAS system logs.
