LITS1337's avatar
LITS1337
Readynas 6 drive replacement issue- volumes inactive
Had a degraded drive, which I replaced (slot 2) per the Netgear provided guides.  Now I have an error stating "Remove inactive volumes to use the disk. Disk # 1,3,4,5,6"
I don't see any of the data now
Aug 21, 2019 01:16:18 PM
System: ReadyNASOS background service started.
Aug 21, 2019 01:11:45 PM
System: The system is shutting down.
Aug 21, 2019 01:05:25 PM
Account: User 'Greg' was deleted.
Aug 21, 2019 12:37:48 PM
System: Alert message failed to send.
Disk: Disk in channel 4 (Internal) changed state from RESYNC to ONLINE.
Aug 21, 2019 12:35:15 PM
Aug 21, 2019 12:34:40 PM
System: Firmware was upgraded to 6.10.1.
Aug 21, 2019 12:28:56 PM
System: The system is rebooting.
Aug 21, 2019 12:27:04 PM
Disk: Disk Model:WDC WD40EZRZ-00GXCB0 Serial:WD-WCC7K6ZPRCC4 was added to Channel 2 of the head unit.
Aug 21, 2019 12:23:18 PM
Volume: Volume data health changed from Degraded to Dead.
Aug 21, 2019 12:23:16 PM
Disk: Disk Model:WDC WD40PURX-64GVNY0 Serial:WD-WCC4E5JTFYZU was removed from Channel 2 of the head unit.
Aug 21, 2019 01:00:41 AM
Volume: Volume data is Degraded.
Aug 21, 2019 12:00:20 AM
Snapshot: Snapshot c_1566360017 was successfully created for share or LUN Videos.
Aug 21, 2019 12:00:19 AM
Snapshot: Snapshot c_1566360017 was successfully created for share or LUN sharpinvestigations.
Snapshot: Snapshot c_1566360017 was successfully created for share or LUN Pictures.
Aug 21, 2019 12:00:18 AM
Snapshot: Snapshot c_1566360017 was successfully created for share or LUN Music.
Snapshot: Snapshot c_1566360017 was successfully created for share or LUN Documents.
Aug 20, 2019 05:34:02 PM
Snapshot: Snapshot prune worker successfully deleted snapshot 2019_06_22__00_00_00 from share or LUN Videos.
Snapshot: Snapshot prune worker successfully deleted snapshot 2019_07_17__00_00_29 from share or LUN Videos.
Aug 20, 2019 05:34:01 PM
Snapshot: Snapshot prune worker successfully deleted snapshot 2019_06_22__00_00_00 from share or LUN sharpinvestigations.
Snapshot: Snapshot prune worker successfully deleted snapshot 2019_07_17__00_00_29 from share or LUN sharpinvestigations.
Snapshot: Snapshot prune worker successfully deleted snapshot 2019_06_22__00_00_00 from share or LUN Pictures.
Aug 20, 2019 05:34:00 PM
Snapshot: Snapshot prune worker successfully deleted snapshot 2019_07_17__00_00_29 from share or LUN Pictures.
  • StephenB's avatar
    This bit looks unusual:
    Aug 21, 2019 12:27:04 PM Disk: Disk Model:WDC WD40EZRZ-00GXCB0 Serial:WD-WCC7K6ZPRCC4 was added to Channel 2 of the head unit.
    Aug 21, 2019 12:23:18 PM Volume: Volume data health changed from Degraded to Dead.
    Aug 21, 2019 12:23:16 PM Disk: Disk Model:WDC WD40PURX-64GVNY0 Serial:WD-WCC4E5JTFYZU was removed from Channel 2 of the head unit.
    Aug 21, 2019 01:00:41 AM Volume: Volume data is Degraded.
    Are you sure you swapped the correct drive?
    • LITS1337's avatar
      LITS1337
      Yes, it is definitely the correct drive.  I found it so strange it went from degradated to dead immediately upon removal.
      • StephenB's avatar
        Can you post mdstat.log (from the log zip file)?
ProSupport for Business
