sky_chicken
Feb 07, 2012Aspirant
Readynas 6 Plus destroys volume after shut down with 4.2.19
Just a quick warning for someone who is using the new firmware 4.2.9 x86 (drives 3+ TB) and the new Hitachi 4 TB (3.7TB) drives in 6 slot configuration. I followed the instruction and did test it 3 t...
sky_chicken
I noticed that this only happens when I shut down the ReadyNAS 6 PLUS. Reboot seems to work just fine. AWhen shut down and turn on after 2 minutes the ReadyNAS shows "READYNAS" for 3 minutes and that "factory reset" and starts within 10 minutes to create the "C" volume. I am trying right now with 5 disc only (14 TB) to see if this is related to the 16 TB expanding limitiation. The release note says you can go over 16 TB when all 6 disc are ii and factory reset is done. Does anyone here has his redyNAS running with 18 TB? (6x4TB)
After removing all HDD's except one in slot one I still have the same problem so my conclusion is that the Readynas will not work with Hitachi 4TB (3.7) at all or my unit is defective. I am going to return it to Fry's and hope that will solve this case.
