bgrubb1
Nov 11, 2013Aspirant
ReadyNAS 6 pro power down mode
Is there anyway to "trick" the Readynas 6 Pro into going into power down mode during 2 different intervals ?? I have mine set to power down from 3PM to 6PM (Peak Energy Hours), but no one uses it in ...
mdgm-ntgr
Nov 11, 2013NETGEAR Employee Retired
You might be able to do it. But you would need to manually edit some config files. Are you comfortable with using SSH?
