gazgaz
Jan 19, 2017Aspirant
readynas 716x failed after attempt to upgrade hard drives from 6tb to 8tb
Hi all I have failure go access all info on my readynas after I stared to upgrade the disks from wd 6tb to wd 8tb hard drives pulled one and replaced - info degraded overnight seemed to repair ...
- Jan 19, 2017
gazgaz wrote:
can I put all the original discs in and reboot ?
Likely not, unless there were not files written to the volume over the several days you were upgrading. The expansion would probably get in the way too.
you should probably contact support - you might need data recovery.
Jan 19, 2017Guru - Experienced User
- gazgazJan 21, 2017Aspirant
Ok
Thanks for the advice Stephen
I packed it up and sent it away to the specialists to see if they save anything
Gary
