gazgaz's avatar
gazgaz
readynas 716x failed after attempt to upgrade hard drives from 6tb to 8tb
Hi all I have failure go access all info on my readynas after I stared to upgrade the disks from wd 6tb to wd 8tb hard drives   pulled one and replaced - info degraded overnight seemed to repair ...
  • StephenB's avatar
    Jan 19, 2017
    gazgaz wrote:
    can I put all the original discs in and reboot ?
    Likely not, unless there were not files written to the volume over the several days you were upgrading.  The expansion would probably get in the way too.
    you should probably contact support - you might need data recovery.
ProSupport for Business
