joeycatanese's avatar
joeycatanese
Follower
Oct 13, 2017
ReadyNAS Admin Page is Offline
New ReadyNAS unit. I have it booted up and on a LAN with a laptop for configuring. RAIDar 6.3.0 program shows the status as Healthy, Firmware 6.6.0, IP Address of 169.254.1.237, all four HDDs are showing green checkmarks. Laptop is configured as 169.254.1.230/24 and networked to the NAS vis a TPLink TL-SF1008D. I can navigate to https://169.254.1.237/admin and log in using the default password, but then I get the Admin Page is offline error, using both IE11 and Firefox 56. There seems to be no networking issues, as the laptop can ping the machine. There is no troublshooting option in the RAIDar utility. I have already "gracefully restarted" the NAS.
Any other options?
  • Is the volume still shown as syncing in RAIDar?  If so, that can cause glitches in the interface.
    If not, then the NAS runs from the OS installed on the drives, not from flash, and it sounds like something may have gone wrong when it installed it on your drives.  Try an OS re-install from the boot menu: /How-do-I-access-the-boot-menu-on-my-ReadyNAS-102-202-212-or-312.  Since you haven't put any data on it yet, doing a complete factory reset from the same menu is another option, but it will have to re-sync your volume again.
    • StephenB's avatar
      If you purchased this new, then you are entitled to free phone support - try my.netgear.com
ProSupport for Business
